| PDF version | Is supported by |
| PDF 1.3 | Adobe Acrobat 4.x and later |
| PDF 1.4 | Adobe Acrobat 5.x and later |
| PDF 1.5 | Adobe Acrobat 6.x and later |
| PDF 1.6 | Adobe Acrobat 7.x and later |
| PDF 1.7 | Adobe Acrobat 8.x and later |
If you edit a PDF document of a different version than your version of Adobe Acrobat , you may be changing the PDF version of the document without realizing it. For example, suppose you have a PDF document which was last saved in Adobe Acrobat 5.x. The PDF version of this document is 1.4. You open this PDF document in Adobe Acrobat 7.x, change it and save it. Normally, you will then change the PDF version of this document to 1.6. To prevent this, you can select the option Prevent the automatic increase of the PDF version.
