About QuickRuns
A QuickRun is a series of Action Lists, Global Changes and a Preflight Profile grouped together as a single command. It is similar to a “sequence of macros” in other applications.
A QuickRun can include:
Note: You can combine Action Lists and a Preflight Profile in hot folders in Enfocus PitStop Server.
When to use QuickRuns?
There may be situations where you need to run multiple Action Lists or Global Changes in a PDF document and then run a Preflight Profile to preflight the PDF document. And you may need to do this repetitively: not just in a single PDF document, but several times or in several PDF documents. Instead of running the individual Action Lists, Global Changes and the Preflight Profile sequentially, it is more efficient to collect these in a QuickRun.
