If you have a large number of PDF documents which you have to check against a specific Preflight Profile, you may have the need to automate this process.
PitStop Server offers automated preflighting of PDF documents. You can create hot folders in which you include a given Preflight Profile and, if necessary, Action Lists (see also Automating tasks with Action Lists, Global Changes and QuickRuns). PitStop Server will then monitor a user-definable input folder at regular intervals and automatically check each PDF document which is put into this folder. Valid and invalid PDF documents will automatically be moved to a respective folder, together with a Preflight Report, if required.
More information about PitStop Server is available on our Web site: www.enfocus.com.
