Content of a report
You can run an Action List or Preflight Profile to check and change your PDF document. If you do so, you can view a report of these actions. The report generated by PitStop Pro is also a PDF document. It can include the following sections:
Section Content
Errors, Warnings & Fixes (Potential) problems according to the selected Preflight Profile and changes which have been made in the PDF document
General File Information Properties of the PDF document, such as PDF version, title, author, etc. and security information
Font Information All fonts used in the PDF document, along with their attributes (type of font, embedded or subset, etc.)
Image Information
All images in the PDF document, along with additional information (for example physical and effective resolution, page, angle, custom color func­tions, etc.)
OPI Information OPI usage in the PDF document
Color Information All color spaces (RGB, CMYK, etc.) used in the PDF document, with additional information where required
Ink Information CMYK ink coverage calculated for the whole document and for each page separately.
Layer Information Properties of the layers that are present in the document. A clickable tree view shows the sequence of the layers.
To have this information shown in a report, you need to select the appropriate checkboxes in the Setup of your Preflight Profile. For example, if Layers is selected, the report will contain a Layer Information section (see Defining the general properties of a Preflight Profile).
Note that you'll find the same information in your report, if you're using the Gather (ink, layer,…) information Actions.
