An important thing to remember when talking about overprint is the concept of “common inks”, meaning inks which the background and the foreground objects have “in common”. We talk about inks, not colors, because the overprint and knockout concepts are relevant in print only, not when you view the PDF documents on screen.
The principle here is as follows: If there are common inks, the foreground inks win, even if their tint value is lower than the corresponding one of the background ink.
Suppose you have a CMYK object set to overprint on a spot color background. Their inks are as follows:
| Ink | Background object | Foreground object |
Cyan |
100 % |
Magenta |
0 % |
Yellow |
0 % |
Black |
0 % |
Red |
100 % |
C: 100 % M: 0 % Y: 0 % K: 0 % Spot color: Red |
Let’s convert the Red spot color of the background to CMYK with the following tint values:
Cyan |
0 % |
Magenta |
100 % |
Yellow |
100 % |
Black |
0 % |
C: 100 % M: 0 % Y: 0 % K: 0 % |
The cyan foreground object has been set to overprint, but still, the magenta and yellow in the background are knocked out. Confused? Remember the basic principle: If there are common inks, the foreground inks win, even if their tint value is lower than the corresponding one of the background ink and even if this tint value is equal to zero.
Let’s put the tint values of the above example in a table:
Ink |
Background object |
Foreground object |
Resulting color |
Cyan |
0 % |
100 % |
100 % |
Magenta |
100 % |
0 % |
0 % |
Yellow |
100 % |
0 % |
0 % |
Black |
0 % |
0 % |
0 % |
See what happened? All inks are now common, even if they have a tint value of 0 %. The foreground inks win and therefore, the 0 % magenta and yellow of the foreground object will be used, not the 100 % of the background.
