Color spaces
A PDF document can contain objects of different color spaces: Separation, DeviceN, CMYK, Gray, calibrated Gray or RGB, Lab or ICC-based colors. The color space of the object has an impact on the object’s overprint behavior. The following rules apply here:
Color space Object type Overprint mode Rule
Separation
DeviceN
Irrelevant
Irrelevant
Only those inks are specified as listed in the respective color space.
Separation Black, for example, will only have the black ink specified, not cyan, magenta or yellow.
Gray
RGB
Lab
ICC-based colors
Calibrated Gray or RGB
Irrelevant
Irrelevant
Cyan, magenta, yellow and black inks are specified. To determine the percentage of the inks in non-CMYK objects, the colors in these objects are converted to CMYK according to the normal color conversion rules.
An object in Gray, for example, may have the following inks specified:
C: 0 %
M: 0 %
Y: 0 %
K: 60 %
Consequently, objects in Gray will always knock out the underlying cyan, magenta or yellow, regardless of the object type or overprint mode.
CMYK
Shading
Irrelevant
Text
Line art
Image masks
Standard (OPM 0)
Illustrator (OPM 1)
Only those inks are specified of which the tint value is not equal to zero.
We learn the following from this overview:
