Paragraphs as logical text entities
If you need to make comprehensive changes to text which spans across multiple lines, you can use the Edit Paragraph tool . You can use this tool to select a “logical text entity”. A logical text entity is generally a chunk of text between two punctuation marks or spaces, or with different font properties. You can also use it to add a new paragraph of text to your PDF document.
