Note: This preference is only applicable if you want to use a floating license from
Workgroup Manager (instead of a traditional product license or a subscription, activated through
the About panel). For more information, refer to the Workgroup Manager documentation.
Proceed as follows:
- Enter the address of the computer running the Enfocus PitStop Workgroup Manager:
- Click Select Server and select one of the detected Workgroup
Manager servers, OR
- Enter the IP Address or the server name.
Note: The IP address of the license server can be found in the status bar of Workgroup
Manager. You can select it, and copy-paste it into the Address
textbox.
- If the computer is accessible through another port than the default port, disable
Use Default Port and enter the port number to be used, for both the
License Server (= the service that will verify your PitStop Pro license) and the Workgroup
Manager (= the service that will distribute the Presets). The port of the Workgroup Manager can
also be found in the status bar of Workgroup Manager. The port of the PitStop Workgroup Manager
is filled out automatically when you enter the server address using the Select Server button
(see previous step).
- Click OK.
You can now start working with PitStop Pro using a
floating license from the Workgroup Manager.
