Paste copied objects
Use this option when you want to copy an object and paste it with an offset. The objects will be pasted with an offset of the coordinates you enter here in the Horizontal Offset and the Vertical Offset textboxes.
For example: If you enter 5 pt in the Horizontal Offset and the Vertical Offset textboxes, when you paste the copied object, it will be placed lower and to the right by 5 pt when compared to the original object.
Example: Horizontal offset (right) (A) and vertical offset (down) (B)
