| # | Description |
| 1 | Name of the Action List, Global Change or Preflight Profile and the number of changes.
In the above example, only one change has been carried out. The icon |
| 2 | Click the Actions link and select Show
Report to view a Report with information about the PDF being processed (e.g.
document properties, security information, the performed Actions,...). Note: If you have used an Action of the type "informs", you should open the Report to find
the information you wanted to collect with the Action List!
| 3 | Select the checkboxes if you want to highlight and/or select the objects that have been affected by the performed Actions, Global Change, or Preflight check. |
| 4 | The Description section indicates which objects have been
changed. Select a line to see the corresponding details in the Details
section below. This way you can browse through the results. Note: It may be handy to use
this browser in combination with the Enfocus Inspector to see more details about a
particular problem or to correct the problem immediately. For more information, refer to
"Browsing throught the results" in the PitStop Pro Reference Guide.
| 5 | The Details section provides information about the items selected under Description. |
| 6 | The Solution section allows you to fix problems, in case of warnings or errors. For example, if an Action of the type "Check" has detected a font problem, you will get the possibility to select an alternative font and change the font immediately. |
