Using operators in Action Lists
About operators in PitStop Pro
PitStop Pro provides a number of operators, allowing you to combine several Actions in a logical way.
These operators can be found in the Action List Editor, under Selections (in the folder Operators).
Currently, following operators are available:
  • AND, OR, NOT - explained below.
  • Select all - is added automatically to new Action Lists, to avoid that you forget to select anything.
  • Select last added objects - allows you to use the result of a previous "add" Action.
  • Duplicate/Remove top of selection stack - are mainly used internally by PitStop Server and should not be used when manually creating Action Lists.
Rules of thumb
