You can make simple or more advanced brightness and contrast adjustments to pixel images of all color spaces (example: RGB) and image types (example: JPEG).
| You can make | Description |
| Simple adjustments | Applies the same amount of brightness and contrast to a complete
image. Location: Enfocus Inspector dialog box: You can perform this on:
| Advanced adjustments (= curve editing) |
Applies a different amount of brightness to each input brightness value. Location: Enfocus Inspector dialog box: The amount of output brightness is represented by a curve that you can edit. You can perform this on:
Tip: Curve editing is not available in the Action List editor, but you
can record it as an action, and then use it in an Action List.
