The QuickRun Editor
The QuickRun Editor is accessible from within the QuickRuns dialog: when double-clicking a QuickRun (or selecting Edit from the contex menu), this dialog appears. It allows you to edit the content of a QuickRun.
The QuickRun Editor consists of the following screen parts:
# Description
1
The name of the QuickRun and a description of what the QuickRun does.
2
The Action Lists, Global Changes and the Preflight Profile that will be applied when running the QuickRun.
3
A number of buttons allowing you to configure the contents of the QuickRun:
  • and : Use these buttons to change the order of execution.
  • Export to Local: As you cannot edit the content of a QuickRun, you can use this button to export the selected item (e.g. an Action List) to the Local folder, switch to the corresponding preset type (e.g. Action Lists dialog), edit it there and afterwards import it again into your QuickRun.
  • and : Use these buttons to add or remove Action Lists, Global Changes and/or a Preflight Profile to the QuickRun.
4
The bottom part of the dialog allows you to set some preflight related options, to define the page range the QuickRun should be applied to, and whether or not the results should be shown.
