You can see four databases, Favorites, Recent, Standard and Local.
| Database | Description |
| Favorites |
This database contains shortcuts to Presets in the Standard and / or Local database that you added to your favorites. To add a Preset to your favorites, see Adding a Preset to your Favorites. |
| Recent | This database automatically shows the last 10 presets used. |
| Standard |
This database contains the default Presets installed with PitStop Pro. You can edit these Presets, but you cannot save an edited Preset to the Standard database. If you want to save an edited Preset, duplicate it from the Standard to the Local database first, then edit the duplicate. |
| Local |
This database contains the Presets you edited or created, and that are only accessible to you. You can edit and rename these Presets as you wish. You can also organize them into groups (see Sorting and grouping Presets). |
