About Smart Preflight
Smart Preflight is a functionality that allows you to handle many different job types and specifications by using only one Preflight Profile. This is possible, thanks to the use of variables.
For example, if one of your preflight settings checks the page size, it is sufficient to define one Profile using a variable with the most commonly used page size (e.g. A4) as the default. If a document type with a different page size comes in (e.g. a leaflet or a newspaper), you can select the required page size from a pre-defined list or type the appropriate value (depending on how the variable is defined) in the dialog that pops up when running the preflight check.
There are two types of variables:
These two types of variables can be combined (i.e. rule-based variables calculated based on a drop-down of constant variables), making it possible to configure multiple checks and fixes based on a single user input (PitStop Pro) or on only one value in a Job Ticket or database.
  Constants
User input
Constants
Job Tickets
Constants
Databases
Rule-based
PitStop Pro
PitStop Server
PitStop Server with Enfocus Switch
Enfocus Connect/Connectors
Note: Variables can be used in Action Lists as well, in a similar way as in Preflight.
