When running a preflight check, the default value is not shown in the dialog that pops up.
Variables can only be used if the Variable Set they are contained in is applied. If this is not the case, the default values are blank.
Check which Variable Set is currently applied and make sure the right Variable Set is active.
You can find the currently applied Variable Set under the PitStop Pro Preferences (Variable Sets).
