When running a Preflight Profile or an Action List with variables enabled, the dialog in which you have to enter values displays the variables in red.
The variable has changed or has been removed from the Variable Set since it was applied in the preflight check.
Check and/or fix the Variable Set and re-apply the variable to the preflight check. The red color will disappear.
