Moving an object or a copy of an object by dragging
  1. Display the Enfocus Inspector.
  2. Using the Select Objects tool , select the object which you want to move.
    You can hold down the SHIFT key and click the left mouse button to select multiple objects.
  3. Do one of the following:
    • Click the Move Selection tool .
    • Hold down the CONTROL (CTRL) key (Windows) or Command ( ) key (Macintosh).
    The pointer changes from into .
    The Enfocus Inspector changes accordingly.
    Tip: If you have enabled Move objects when dragging selection in the Enfocus PitStop Pro Preferences, you can skip this step. See Move objects when dragging selection.
  4. If necessary, change the Measurement Units in the Enfocus PitStop Pro Preferences.
    Note: In the Numeric Feedback area you can find exact information about the move you are about to perform.
  5. Do one of the following:
    • Drag the selected object to a new location.
    Example: Moving the selected object to a new location by dragging.
    • Hold down the SHIFT key and drag the selected object confined to a horizontal or vertical direction.
    Example: Holding down the SHIFT key while dragging moves the object along a fixed vertical or horizontal axis.
    • Hold down the ALT key (Windows) or Option key (Macintosh) while dragging to create a copy of the object in the new location.
    Example: Holding down the ALT key (Windows) or Option key (Macintosh) while dragging the object creates a copy of the object in its new location.
    • Use the arrow keys to move the object (while still holding down the CONTROL (CTRL) key (Windows) or Command ( ) key (Macintosh)).
      Note: Using the arrow keys to move the object is only possible if you have cleared the Move objects when dragging selection checkbox in the Enfocus PitStop Pro Preferences. See Move objects when dragging selection.
