Adding a session comment
The Certified PDF mechanism in PitStop Pro enables you to enhance the quality of your PDF workflow by adding comments to the Edit Log. Before sending your PDF document to the publisher for example, you may want to explain why given changes have been made.
You can add comments per editing session. A session is the time in which you edit and save a PDF document.
To add a session comment
  1. Make the required changes.
  2. Choose File > Enfocus Sign and Save (As).
  3. Add a new session comment.
    You will find this comment in the Edit Log (Session info, under Comments).
  4. To save the current version of the document as a snapshot (so you can re-use it later), select the Keep Snapshots checkbox.
    For more information, refer to Snapshots.
  5. Click OK.
