Using the Color Management Preset Editor
Define the name and Description
If you want to use the active settings in your preset, select
Grab current Color Management
Preferences from the Actions menu. All
these settings will be entered automatically.
If you want to use the Acrobat Preferences in your preset, select
Grab current Acrobat
Configure the general color management settings in the
General tab.
In the Images tab, you can select the Apply
General color settings checkbox to apply the general settings
for the images too or you can select the Enable color
management checkbox to override the general color settings and
configure separate settings for images.
Select a default source and target ICC profile for each color
space. By selecting Sync with Acrobat, the corresponding
ICC profile defined in the Acrobat preference will be used.
Select the CMM Engine to be used, and (if
applicable) select Use black point compensation
checkbox.
Click the Save button to just save the
settings or click the Save and Apply button to apply the
settings too.
