To apply a color from the color database to text or objects
Once you have stored a color in your User Swatches, you can apply this color to objects or text in your PDF document. You can also select predefined colors, or import color libraries.
Proceed as follows:
  1. Using the Select Objects tool , click any text or line-art object in the PDF doc­ument to which you want to apply a color from your User Swatches.
  2. Display the Enfocus Inspector.
  3. Click the Fill and Stroke category, and select Color Picker from the Actions drop-down menu.
  4. Select the Color Library from which you want to use a color, e.g. select "Local" to select a color you defined using Add color to Local color database
  5. Select a color from the database. More information on the color is shown on the right.
    Note: You can create a new color based on the selected color, by changing the sliders and the name, and clicking the Save Color button.
  6. Click OK to apply the selected color.
  7. If necessary, adjust the selected color using the sliders in the Enfocus Inspector.
