To change the overprint settings of an object
Make sure overprint previewing is on in Adobe Acrobat (
Advanced > Overprint Preview)
Using the
Select Objects
tool
, select an object.
Display the Enfocus Inspector.
See
Opening the Enfocus Inspector dialog
Select the
Fill and Stroke > Overprint
category.
Change the
Fill
or
Stroke
overprint settings.
= on
= off
If necessary, select an
Overprint Mode
: OPM 0 or OPM 1.
Note:
You will only see a difference between the overprint modes if you turned the Adobe Acrobat overprint previewing on, as described in step
Parent topic:
Changing the overprint settings of an object
