To split or merge a text segment
  1. Open the PitStop Inspect panel (under Tools) and click .
    The Enfocus Inspector is displayed.
  2. Click the Text category.
  3. Using the Select Objects tool , select one or more text segments which you want to split.
  4. Choose any one of the following options from the Actions menu:
    • Split in Characters
    • Split in Words
    • Convert Text to Outlines
    • Merge into Text Lines or
    • Merge into Words
    Note: The options listed above are also available in the submenu of PitStop Pro > Object.
