Editing a workspace
To edit a workspace
  1. Open the Enfocus Workspace Panel.
  2. If the workspace you want to edit is a default workspace (found under Standard), drag it to the Local database.
    The workspace is duplicated automatically; the workspace name will be followed by a number between brackets.
  3. In the Local database, double-click the workspace to edit.
    The workspace is opened in the Enfocus Workspace Editor.
  4. Edit the workspace as needed.
    For more information about the settings, refer to the topics under Workspace settings.
    Note: You can also grab settings from your current Acrobat / PitStop Pro interface and use them in your workspace:
    • Click the Actions menu and select Grab All Categories to grab all the current settings for your workspace.
    • Select a category, click the Actions menu and select Grab Current Category to grab the current settings related to this category (for example, all Acrobat View settings).
  5. When you are done, click OK to save the changed workspace.
