Using Design Layouts
Using Design Layouts, you can modify page boxes and zones, add guides, etc.
To work on page boxes, zones, or guides:
  1. Select a Design Layout
    This can be one of the default Design Layouts, or a Design Layout you created yourself.
  2. Modify the Design Layout if needed:
    1. Using the Edit Design Layout tool to manually edit guides, zones and page boxes
    2. Using the Enfocus Design Layout Editor to change the Design Layout numerically
    After changing the Design Layout, you can save the changes to the Design Layout, or revert to the saved version.
  3. If necessary, apply the Design Layout to the page or to the complete document.
  4. Deactivate the Design Layout to stop showing guides, zones and page boxes.
