Adding folders to the Preflight Profile Compare Panel
You can easily import Preflight Profile Compare Configuration files (*.ppc files) on your local computer into the Preflight Profile Compare Panel.
To do so
  1. Place the *.pcc files in one or more folders (and subfolders if needed) on your computer.
  2. Choose Edit > Preferences > Enfocus StatusCheck Preferences (on Windows) or Acrobat > Preferences > Enfocus StatusCheck Preferences (on Mac).
  3. First, click the Database category, then click Preflight Profile Compare.
  4. Click .
  5. Select the folder that contains the configuration files.
  6. Click Select Folder.
    The name of the imported folder and the path on your computer are shown in the Enfocus StatusCheck Preferences dialog.
  7. If you don't want to allow users to change the imported folder from within the Preflight Profile Compare Panel, select the Read-only checkbox.
  8. Click OK.
    The folder is added at the highest level in the Preflight Profile Compare Panel. This is different from folders being imported from within this panel (using the > Import/Export > Import Group option), which are imported as a subfolder of the Local folder.
