To apply gradients
  1. Select text or line-art objects.
  2. In the Enfocus Inspector dialog box, do one of the following:
    If you want to apply Then
    A gradient fill
    1. Click > .
    2. Click .
    3. If necessary, click Actions, and select a different color model (example: Convert to RGB).
    A first control bar, and options and buttons to change the gradient are displayed in the Enfocus Inspector dialog box.
    A gradient stroke
    1. Click > .
    2. Click .
  3. In the Tools pane, click PitStop Edit > .
    A second control bar to change the gradient is displayed on the PDF document.
  4. Make the necessary changes using:
    • The options and buttons in the Enfocus Inspector dialog box.
    • The first control bar in the Enfocus Inspector dialog box.
    • The second control bar on the PDF document.
