Once you have defined your Variable Set, you must "apply" or activate the Variable Set you want to use. This is important if you have defined more than one Variable Set; if the variables used in your Preflight Profile are taken from a different Set than the one that is activated, the variable values in the Profile will remain blank (unless variables with the same name are used in both Sets).
To apply a Variable Set
