To combine the shapes of multiple objects
To combine the selected objects into a new shape
  1. Select at least two objects using the PitStop Select Objects tool .
  2. Do one of the following:
    • Select PitStop Pro > Object > Combine/Divide Shapes
    • Open the context menu and choose Combine/Divide Shapes
    • Open the Enfocus Inspector and select Line Art Editing - Combine and Divide Shapes.
  3. If you're using the Enfocus Inspector, clear or select the Keep original objects checkbox as required.
  4. Select the option of your choice.
    • Unite: Combines the selected objects into a single shape.
    • Intersect: Keeps the areas where objects are stacked on top of each other.
    • Exclude: Keeps the areas where an odd number of objects are stacked on top of each other.
    • Minus front: Keeps the areas of the bottom shape which are not overlapping with the overlying shapes.
    • Minus back: Keeps the areas of the top shape which are not overlapping with the underlying shapes.
The shapes are immediately converted into one shape.
