To divide shapes into multiple parts
Dividing shapes means breaking them apart wherever the lines intersect. For example, two overlapping shapes will be divided into three parts (the intersection will become a separate part).
To divide objects
  1. Select the objects using the PitStop Select Objects tool .
  2. Do one of the following:
    • Select PitStop Pro > Object > Combine/Divide Shapes
    • Open the context menu and choose Combine/Divide Shapes
    • Open the Enfocus Inspector and select Line Art Editing - Combine and Divide Shapes.
  3. If you're using the Enfocus Inspector, clear or select the Keep original objects checkbox as required.
  4. Click Divide.
The shapes are divided and each part can be processed separately.
