To find and replace text
  1. Do one of the following:
    • Choose PitStop Pro > Object > Enfocus Find And Replace Text.
    • In the PitStop Edit panel (under Tools) click .
  2. In the Find And Replace Text dialog box, type the text you want to search in the Find textbox.
  3. Select the appropriate options:
    • Case sensitive if you want to find the exact word that you type (i.e., upper case or lower case).
    • Current page only to restrict your search to the current page of focus only.
    • Select partial text objects if your search query is only a part of a whole word.
  4. To check all found (and highlighted) instances of the search term one by one, click Next (to start from the current page), or Previous (to go back to the beginning of the document).
  5. To replace the search term with another word of your choice
    1. Type the word in the Replace textbox.
    2. Click Replace to replace a search term which has already been highlighted, or Find & Replace to replace the currently highlighted search term and find the next instance of it.
