If you want to import multiple QuickRuns, you may want to group them into a
folder and import this entire folder into the application. In that case, choose
Import Group and select the appropiate folder on your
system.
Select the appropriate QuickRun.
Click Open.
The imported QuickRun appears in the Local folder in the QuickRuns dialog. You can
run and/or edit this QuickRun as required.
