Removing Actions from an Action List
If you want to remove Actions that were added by accident, or Actions you don't need after all, you can simply remove them from the Action List.
To remove an Action
  1. In the Action List Editor, select the Action(s) you want to remove.
  2. Do one of the following
    • Right-click and select Remove.
    • Click .
    The Action is removed from the Action List.
    Note: Remember that you can put the Action back, by selecting it from the list of available Actions. However, if you had made any changes to the attributes, these haven't been saved, so you will have to set them again.
