Rotating an object by dragging using the selection handles
To rotate an object by dragging using the selection handles
  1. In the Enfocus Inspector dialog, click the Select Objects tool .
  2. Select the object(s) you want to rotate.
  3. Move your pointer near (but outside) one of the selection handles in the corner of the bounding box, until it becomes a curved arrow as in the graphic below.
  4. Hold down the left mouse button while dragging the handle to the desired position.
    Note: To rotate the object in fixed angles (multiples of the angle point), hold down the SHIFT key while dragging.
    The selected object is rotated around its center point.
    If multiple objects are selected (as the two text segments in the graphic below), they are all rotated in one go, around the center point of the selection.
    Object Description
    1. Multiple selection
    2. Rotated (before releasing the mouse button)
    3. Result
