To run a Preflight Profile
  1. Open the Preflight Profiles dialog box.
  2. Select a Preflight Profile.
  3. If necessary, change the following options:
    • Certified PDF Preflight: Select this checkbox if you want the Preflight to be part of a Certified PDF workflow. See also Difference between a regular and a Certified preflight check.
      Note: A Certified PDF Preflight is always run on the complete document. When choosing Certified PDF Preflight, the page selecting options (under Run on:) will be unavailable.
    • Run on: Set the page range on which you want to run the Preflight Profile.
    • Allow fixes: Define if fixes should be performed. If the Preflight Profile doesn't allow fixes, the option will be disabled.
  4. Click .
After finishing, the Enfocus Navigator will show all errors, allow to restart the Preflight, suggest solutions, etc. See Using the Enfocus Navigator.
