The attributes you can set depend on the selected Action. Some Actions do not require
any attributes; for others you should enter the preferred values, for example a
length or a version number, pick a color, select an option from a list, select a
checkbox, ... Setting the attributes is in most cases quite obvious.
Note: If an attribute of an Action requires a unit, for example a length, the unit
specified in the PitStop Pro
Preferences (Units & Guides Category) is used. For example, if you're using
the Select size Action, you have to determine minimum or maximum width or
the height of the objects you want to select. If you have selected "cm" in the
PitStop Pro Preferences,
you will have to specify a value in "cm".
This topic explains the "special cases":
- How to use variables instead of fixed values.
- How to use regular expressions
- How to log "check" Actions
- How to use the Use page rotation (and scaling factor)
checkbox (which is available in a number of Actions)
