In the Enfocus Variable Set Editor, you can review and verify settings within a
Variable Set to ensure the variables work as expected. For example, you can verify
whether values from XML/JDF Job Ticket file are read correctly.
Note: This doesn't
change any settings, it merely simulates the use of the Variable Set.
To check the variables in a Variable Set
