Restrictions are a way to limit the scope of your Preflight check; instead of applying all checks to the whole document, you can now for each (set of) checks define on what part of the PDF the check(s) should be run - be it a PDF page box, a certain page or pages, a particular area or specific elements of a PDF, or even different layers within a PDF file.
Restrictions are defined by Action Lists with Select Actions only. You can create your own restricting Action Lists, or use pre-defined, ready-to-use restricting Action Lists, installed with PitStop. These restrictions must be imported into the Profile, in order to use them.
For each group of checks (i.e. each category under Check on), you can decide which restriction applies (if any). If more than one restriction applies for one category, you can use separate tabs (one tab per restriction) as shown below.
Suppose you want to check a PDF for both very small/colored and invisible text. The threshold for text size is different for the cover page and the other parts of the document, whereas invisible text should be detected, regardless of where it is found.
If a check is limited by a restriction, in the Preflight Report, by default the name of the restriction is mentioned in front of the actual warning. If no restriction is applied, this is not mentioned explicitly. You can hide the restriction names by clearing the Restriction names checkbox in the general properties of the Preflight Report.
