Hot folders in an Enfocus PitStop Server environment
"process" incoming documents automatically and place these documents in a given folder,
depending on the process result. What do we understand by processing?
Processing can mean the following:
- A PDF document can be checked against a Preflight Profile and corrected correspondingly.
A Preflight Profile is a set of
user-defined criteria which define whether a PDF document is output-worthy or not.
- An Action List can be applied to a PDF document. An Action List is a
series of tasks to edit or correct PDF documents automatically. You
can also use Action Lists to check elements.
- You can combine a PDF Profile and Action List(s) in one processing
method called 'preflight and auto correct'
- Documents other than PDF documents
can arrive in the input folder of a hot folder. Enfocus PitStop Server will detect
that their digital format is not PDF and move these documents to a given
folder.
Note: You can design Preflight Profiles or Action
Lists with products like Enfocus PitStop Pro, a plug-in for
Adobe Acrobat.
