A processed document can have either one of the following results:
Result |
Meaning |
Success |
The processed PDF document meets all the criteria specified in the Preflight Profile without any intervention from Enfocus PitStop Server. and/or The Action Lists were applied successfully and none of the checked or detected properties were logged as “Warning” or “Error”. |
Warning |
The processed PDF document does not meet one or more of the criteria labeled “Warning” specified in the Preflight Profile or One or more of the properties checked or detected by an Action List were logged as “Warning”. |
Fixed |
The processed PDF document meets all the criteria specified in the Preflight Profile after being fixed by the Action List, by the PDF Profile or by an Action List in the PDF Profile |
Non-critical Failure |
A Failure occurred while processing the PDF document, meaning that Enfocus PitStop Server was not able to perform a requested fix (e.g. because a font that should be embedded is not available on the system). The Failure is set in the Action List as a “non-critical failure”, or it occurred on a fix from the PDF Profile. |
Error |
The processed PDF document does not meet one or more of the criteria labeled “Error” specified in the Preflight Profile. or One or more Action Lists could not be applied successfully or one or more of the checked or detected properties were logged as “Error”. |
Critical Failure |
A Failure occurred while processing the PDF document, meaning that Enfocus PitStop Server was not able to perform a task (e.g. because a font that should be embedded is not available on the system). The Failure is set in the Action List as a “critical failure”. |
Non-PDF |
The document which arrived in the input folder is not in PDF format. |
