Problem severity levels defined
If any of the properties in a PDF document does not comply with the settings as speci­fied in the Preflight Profile, it will be logged in the preflight report and, if you have Enfocus PitStop Pro installed, also in the Enfocus Navigator. You can select how these deviations should be reported:
These labels indicate severity levels of the detected “problem”. If a property does not comply, you can define how severe the detected problem is:
