From database
The Database contains predefined Action Lists or Preflight Profiles and Action Lists or Preflight Profiles which are already available in the Enfocus Action List Database or the Enfocus Preflight Profile Database. Both are installed on your computer's hard disk along with Enfocus PitStop Server. These databases can also be used and updated by other Enfocus products, such as Enfocus Instant PDF (4.0 or higher) and Enfocus PitStop Pro (7.0 or higher). This means that, if you create an Action List or a Preflight Profile with Enfocus Instant PDF, it will also appear in the From database list in the Selected Action Lists dialog or the Selected Preflight Profile dialog.
The Default database contains Action Lists and Preflight Profiles, installed with the application and available to all users on the computer. The Default database and its contents can not be modified. The Local database level is only available to the current user. Additional folders can be added in the Preferences (see Enfocus PitStop Server Preferences).
