Hot folder priority
In the hot folder list, you can see the priority of the different hot folders. The priority defines the order in which jobs will be processed.
Enfocus PitStop Server will first process all jobs in hot folders with priority “High”. If all those are processed, the jobs in hot folders with priority “normal” will be processed next. Finally, if no jobs with priority “high” or “normal” are waiting to be processed, the jobs with priority “low” will be processed.
For jobs with the same priority, the order will be determined by the time of submission: the job that was submitted first, will also be processed first (FIFO principle: First In, First Out).
