File renaming
By default, the file renaming is set to “%CurrentDocumentName%”, meaning that the output files will have the same name as the original input file. Using the file renaming, the output file names can be built using the “Variables”. When selecting a variable, the “current value” is shown at the bottom. It is also possible to type fixed text, e.g. to add “_log” to the name for the report files.
Variable
Meaning
Example
%User Company%
the company name as defined in the Personal Info
Enfocus BVBA
%Current Document Name%
the file name of the input file
examplefile.pdf
%User Name%
User
%Time%
the current time in hours, minutes and seconds
08_43_28
%UniqueID
a unique sequential number
45
%Date%
the current date
2007-06-18
%Document Status%
the current preflight status of the document
NOK (Not OK)
%Subfolder Name% the name of the subfolder
%Hot Folder Name% the name of the Hot Folder
