The Create Basic Setup... option is a simple way to create a basic folder structure inside a base folder. A base folder is the root folder from which you can make the input folder and the related output folders branch. Consequently, you need to create a base folder only if all related folders — or most of them — have to be subfolders of this base folder.
The Create Basic Setup... option can be used on an existing folder on your computer hard disk or network drive. Using the “Make New Folder” button, a new physical folder can be created as well.
