Preflighting issues
“Preflighting” is the process of checking a PDF document against various criteria to ensure that the PDF document meets all the requirements for output or publication. Typically, the criteria vary depending on the output or publishing process. A set of criteria matching the requirements of a particular process is called a “Preflight Profile”.
Enfocus PitStop Server, for example, allows you to create a Preflight Profile that checks your PDF document against various criteria, such as color and font usage. Moreover, you can use Enfocus PitStop Server to actually fix detected problems in your PDF documents.
Ideally, a PDF document should be preflighted at an early stage in a workflow, i.e. as soon as it has been created. This is particularly true if the PDF document will move from the PDF document provider, who created the PDF document, to the PDF document recipient, for example a publishing or printing department. Detecting problems in the PDF document before the file leaves the PDF document provider saves time (and money). Even more so, when the PDF file is sent to a different physical location.
Note: You can also create Certified PDF documents with Enfocus Instant PDF. For more information about Enfocus Instant PDF, visit our Web site at www.enfocus.com.
