Optimization on save
The Optimization on save section allows you to configure settings which will help optimize the output files. There are three options to choose from:
  1. Optimize for file size and web download
    When you select this radio button, the output files will be optimized to achieve a smaller file size. Also, the objects inside the PDF will be reordered to display the PDF faster. The duplicate objects in the file are merged and the file is linearized for fast web preview. However, it does not change the quality of the file.
    For example, the first page is displayed before the rest of the PDF file is loaded (or downloaded) which generally result in a slightly larger file than when using Optimize for file size only.
  2. Optimize for file size only
    When you select this radio button, the output files will be optimized to achieve a small file size. The duplicate objects in the file are merged to reduce file size. However, it does not change the quality of the file.
  3. Disable optimized save
    When you select this radio button, the output files will not be optimized. No optimization is performed and the quality of the file is not affected.
