Using Smart Preflight
Following is the overview of the step to using Smart Preflight variables within PitStop Server:
  1. Create a Variable Set.
  2. Define the variables to be used based on your XML/JDF Job Ticket.
  3. Edit a preflight profile and locate a check to use a variable.
  4. Enable Variable Names under the “Action” for that preflight check.
  5. Select the correct variable name to be used for that check from the required variable set.
  6. Save your changes.
  7. Add the Preflight Profile and required Variable Set to a hot folder set-up.
  8. Run files (PDF+XML/JDF) through the hot folder set-up.
The following sections will go into more detail about each step.
