Test or verify variables in a Variable Set
In the Enfocus Variable Set Editor, you can review and verify settings within a Variable Set to ensure the variables defined work as expected.
The intent of this feature is to allow you to verify values from XML/JDF job ticket file are defined correctly and to ensure logic defined within Rule Based variables work as expected. This dialog does not change any settings within a variable.
To check a Variable Set select the Tester icon in the Enfocus Variable Set Editor. All the variables within the current Variable Set will be displayed with the values currently defined along with the last XML/JDF job ticket loaded (if any).
Within the Enfocus Variable Set Tester, you can Browse to load a sample XML/JDF job ticket file. By default, the last file loaded is displayed. Below the Sample Job Ticket, the current variables are listed on the left with the values returned from the loaded job ticket for each variable displayed on the right.
If a new job ticket is loaded the values that will be returned from that job ticket are displayed, this functionality enables you to easily test your variables against different sample files to check the expected results will be returned to the preflight profile.
Job Ticket variables and their values will be displayed based on the file loaded along with the XPath defined and any modifications to that field based on the variable settings. If there is an error in the XPath or if the variable does not exist in the sample XML/JDF file, the variable will display in Red. Errors in job ticket values may be the result of errors in any manipulations defined or errors in the XML/JDF sample file. Errors in the XPath or manipulations can be corrected by editing the offending variable.
Rule Based variables that use Job Ticket values to trigger values will change based on the sample job ticket file loaded. These values are not editable within the Tester.
Constant variables and Rule Based Variables that use Constant variables defined in PitStop Pro will be displayed and the Constant variables can be modified for testing. However, PitStop Server will only use the default value from the Constant variable when processing jobs.
