The statistics pane displays information on how long jobs spend in certain folders or states while being moved along a flow.
Switch assembles two types of statistics data:
The time jobs reside in each folder that has the “show in statistics” property turned on.
The time jobs spend in each of the states setup with the “attach job state” folder property.
With a well-chosen set of statistics-enabled folders or states, the statistics charts can help identify performance bottlenecks and can form the basis for further adjustment and improvement.
For more information see Viewing statistics.
You can show up to three statistics panes at the same time (called "Statistics", "Statistics 2" and "Statistics 3"). Each pane remembers its own settings. For example, you could setup one pane to show folder statistics and another pane to show state statistics.
